How to Reach Far Fields Secret Area in Silksong
Reach Hollow Knight: Silksong’s Far Fields secret area in Act 3 via Silk Soar and Hunter’s March to earn the Heart of the Wild reward.
Okay, listen. I have been spelunking through Pharloom since the Act 3 content landed in 2026, and if you are anything like me, you have probably stared at the Far Fields map, noticed that suspiciously blank corner, and thought, “Yep, there is a secret over there.” Good news: there absolutely is. Bad news: Silk Soar does not care about your feelings, and the route to the Far Fields secret area in Hollow Knight: Silksong will make you work for it. Here is how to actually get there without losing your needle, your patience, or your mind.
The Route: Karmelita, Silk Soar, and a Very Sneaky Ceiling
First things first: you need to be in Act 3. A decent chunk of Pharloom only opens up once you reach this chapter, and the Far Fields secret area is one of those additions. If you are still poking around Act 2, go advance the main story before you waste an afternoon jumping at walls.
When you are ready, travel to Hunter’s March. Specifically, find the statue of Karmelita. This is not just a fancy piece of scenery; it is basically your vertical launchpad. Use the Silk Soar Ancestral Art near the statue to leap upward into a hidden passage. I missed this the first time because I kept hugging the ground like a frightened grub. Do not be like me. Look up.
After you make the leap, keep moving to the right. You are aiming for the border between Hunter’s March and Far Fields. Eventually, you will unlock a shortcut that connects the two regions together. That shortcut makes future visits much less painful, so take a moment to appreciate it before the game throws another obstacle at you.
The Shortcut That Betrays You in Act 3
Here is the twist nobody warned me about: if you previously unlocked the shortcut between Deep Docks and Hunter’s March, do not expect to use it in Act 3. It will be closed, and you will stand there pressing buttons like a confused mosscreep.
To get back into Hunter’s March after the Act 3 changes, Hornet has to take the original route from The Marrow. Then, once you are on the Hunter’s March side, smash the boulder that is blocking the way. Yes, this means you have to redo a chunk of the pogo platforming. The saving grace is that Silk Soar lets you skip a large part of that platforming, so it is less “painful flashback” and more “mildly annoying detour.” Spin, leap, pray, and move on.
Far Fields Secret Area: Loot, Quests, and Sweet Rewards
Once you actually enter the Far Fields secret area, it opens up into a surprisingly busy little corner of Pharloom. This is not just a dead end with a single chest. There are real objectives here, and a few of them tie directly into your journey.
🖤 Heart of the Wild
The big prize is the Heart of the Wild, one of the hearts required for the main quest. If you are hunting down essential pieces for progression, this is a stop you cannot skip. I recommend grabbing it as soon as you enter the secret area, because it is easy to get distracted by side paths and forget why you came.
🏃 Sprintmaster Swift and the Fastest in Pharloom Wish
Take the easternmost route inside the secret area and you will eventually reach the home of Sprintmaster Swift. This is where you can fulfill the Fastest in Pharloom wish in Silksong. It is a nice little side objective that rewards you for exploring every edge of the map. I will not spoil the exact conversation, but let us just say Swift lives up to the name.
🚪 Pilgrim’s Rest Connection
The hidden area can also be connected to Pilgrim’s Rest, which opens more routes on top of the existing Pilgrim’s Rest door. This is fantastic if you want to streamline travel across the region. Secret areas are always better when they create new shortcuts instead of just sitting there like a lonely room.
🕷️ The Hidden Hunter Quest
On top of everything else, the Hidden Hunter quest in Silksong also leads Hornet straight into the Far Fields secret area. If you are following that mission, you will end up here naturally, which is a nice bit of design. It turns the secret area from a random hidden nook into a meaningful destination for multiple story threads.
TL;DR for Tired Spiders
Objective
Location / Requirement
Reward or Purpose
Enter secret area
Karmelita statue + Silk Soar in Hunter’s March
Shortcut to Far Fields
Heart of the Wild
Main quest heart
Sprintmaster Swift’s home, easternmost route
Side quest completion
Pilgrim’s Rest connection
Hidden route inside secret area
Opens extra routes
Hidden Hunter quest
Leads Hornet to the secret area
Quest progression
At the end of the day, the Far Fields secret area is one of those Act 3 surprises that makes Pharloom feel bigger than it should. Just remember: check the statue, use Silk Soar, go right, and do not trust the Deep Docks shortcut. Good luck out there, fellow wanderer.
Exploring every hidden corner of Pharloom takes patience, but the payoff is always worth it — and that same mindset applies outside the game. Whether you’re looking for a new controller, Silksong merchandise, or a better gaming setup, the thrill of finding a great price feels a lot like uncovering that secret room behind the statue. So before you hit that checkout button, take a moment to [find the best deal]( and make your coin stretch a little further. After all, saving a few bucks in the real world is its own kind of hidden treasure.
https://dealnesthq.com
