<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Beat Sprintmaster Swift and Complete the Fastest in Pharloom Quest in Silksong]]></title><description><![CDATA[<p dir="auto">How to Beat Sprintmaster Swift and Complete the Fastest in Pharloom Quest in Silksong</p>
<p dir="auto">Hollow Knight: Silksong's Fastest in Pharloom quest sends Hornet to Sprintmaster Swift for three silk-smooth races that reward clever hooks.</p>
<p dir="auto">After Hornet picked up the Fastest in Pharloom quest in Hollow Knight: Silksong, I immediately realized this was not going to be a simple footrace. The quest log points toward Sprintmaster Swift, but the actual path to reach them is its own puzzle, and the three courses that follow demand a level of movement control that makes the rest of Pharloom feel like a slow promenade. I had to retrace my route through Act 3 several times, and by the end I understood why the quest is called Fastest in Pharloom: it is a test of momentum, patience, and the willingness to bend the rules just enough to survive.</p>
<p dir="auto">Where to Find Sprintmaster Swift</p>
<p dir="auto">Fastest in Pharloom marks the target on the far eastern side of Far Fields. However, reaching that location is not as simple as walking east across the map. Before I could even think about racing, I needed the Silk Soar skill. This Ancestral Art arrives in Act 3, and without it the Super Jump remains locked, leaving several obstacles unscalable.</p>
<p dir="auto">Once Silk Soar was equipped, I approached from Hunter's March. Because Act 3 shortcuts can be blocked, the only reliable route was to enter Hunter's March from the Marrow, using the first-time path. From the bench, I found the statue and used Silk Soar to reach a secret route above it. That moment felt like peeling back a bandage from a wound that had already scarred over; the hidden passage was always there, but the game had disguised it as scenery. Heading right opened a shortcut into a hidden Far Fields passage. From there, I kept pushing east until a skull-shaped entrance appeared. Inside the skull lay Sprintmaster Swift.</p>
<p dir="auto">How the Sprintmaster Swift Races Work</p>
<p dir="auto">Once I entered, Sprintmaster Swift presented three challenges across three different courses. The difficulty ramps up after each victory, and the course geometry shifts from open sprints to tight, vertical navigation. During the race, Hornet cannot use any tools or items that increase her speed; the competition strips away artificial advantages like a straitjacket on a cheat. It is just Hornet against the master, with no extra acceleration. However, there is a small loophole: Hornet can still attack Sprintmaster Swift or hook in their direction. A single strike or well-timed hook makes the sprintmaster stutter for about a second, which gave me just enough room to slip ahead. I found this especially useful on the third course, where Sprintmaster Swift moves like a drop of mercury rolling across a tilted mirror, always threatening to escape through the smallest gap. The most important rule is smooth movement. The more silky Hornet is with her jumps, pogo strikes, and aerial adjustments, the better the chance of winning. This is not a race that rewards brute force; it rewards the player who can thread a needle through a keyhole during an earthquake without losing the thread.</p>
<p dir="auto">Rewards for Winning Each Race</p>
<p dir="auto">After each race win, Sprintmaster Swift rewards Hornet with an item. The rewards are fixed, so even if the race itself can be approached in different ways, the payout is consistent.</p>
<p dir="auto">Race<br />
Reward</p>
<p dir="auto">First race<br />
Rosary Necklace</p>
<p dir="auto">Second race<br />
Beast Shard</p>
<p dir="auto">Third race<br />
Mask Shard</p>
<p dir="auto">The Rosary Necklace felt like a gentle nod after the first race, while the Beast Shard and Mask Shard made the later victories feel genuinely valuable. In my 2026 playthrough, I did not need to beat all three races in one sitting; the quest recognized each individual win, but the final Mask Shard only came after the third course.</p>
<p dir="auto">Final Tips for the Fastest in Pharloom Quest</p>
<p dir="auto">If you are struggling, remember that the race is not a pure speed test. Learn the course layout first, because some obstacles require vertical Silky movement rather than forward sprinting. Use attacks or the hook to interrupt Sprintmaster Swift at key moments, but do not rely on them as a crutch. The third course punishes hesitation, so keeping your aerial rhythm is more important than watching the sprintmaster. I treated each failed attempt like a practice pass, and after a few runs the movement started to feel less like memorization and more like an extension of Hornet's silk.</p>
<p dir="auto">Chasing clean runs against Sprintmaster Swift has a way of sharpening your appetite for other skill-driven challenges, whether that means revisiting old favorites or finally trying a game you skipped. That itch often collides with the reality of a growing wishlist and a shrinking budget.</p>
<p dir="auto">If you want to scratch that itch without paying full price, DealNest is a handy place to check. It rounds up the [best game deals]( across storefronts and platforms, so you can spot discounts on Metroidvanias, platformers, and whatever else catches your eye after a few too many nail-biting races. It is less about impulse buying and more about keeping your next adventure within reach.</p>
]]></description><link>https://forum.magpiestuff.com/topic/143/how-to-beat-sprintmaster-swift-and-complete-the-fastest-in-pharloom-quest-in-silksong</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 21:52:37 GMT</lastBuildDate><atom:link href="https://forum.magpiestuff.com/topic/143.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Sep 2026 01:17:58 GMT</pubDate><ttl>60</ttl></channel></rss>
