<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Reach Heart of the Wild and Claim the Hunter&#x27;s Heart in Silksong]]></title><description><![CDATA[<p dir="auto">How to Reach Heart of the Wild and Claim the Hunter's Heart in Silksong</p>
<p dir="auto">Hollow Knight: Silksong Act 3's Heart of the Wild quest challenges players with new Far Fields routes and blocked Hunter's March shortcuts.</p>
<p dir="auto">Hornet's journey through Act 3 of Hollow Knight: Silksong is a hidden extra gameplay layer that only begins after players select a specific ending. Far from a simple epilogue, this route packs a surprising amount of story and combat, and one of its most demanding objectives is the Heart of the Wild quest. To claim the Hunter's Heart, Hornet must travel to the far east of the Far Fields region, a newly opened area that cannot be reached before Act 3 begins.</p>
<p dir="auto">For players returning in 2026, the route can still catch veteran explorers off guard. Shortcuts that once made Hunter's March feel manageable are now sealed, and the area seems to remember Hornet's first visit all too well. The long way around is the name of the game, so players should prepare for a lengthy backtrack with a few extra enemies eager to interrupt the trip.</p>
<h2>Act 3 Unlock and the Far Fields Route</h2>
<p dir="auto">The Heart of the Wild quest location is locked behind the Act 3 story progression. Once Hornet reaches the relevant point in the questline, the far east of the Far Fields opens up. The most reliable starting point is the Marrow. From there, players should enter Hunter's March through the only available entrance, because every shortcut is blocked.</p>
<p dir="auto">The path pulls no punches on this second visit. In the first run, players may have relied on careful pogo timing, but this time Hornet has better tools. The Silk Soar skill can skip several troublesome spots, and a crest with a downward hit can turn the plunge attack into a reliable movement option. Don't sleep on the Silk Soar here—it is the key to reaching the eastern statues without losing too much health.</p>
<h2>Crossing Hunter's March Without Shortcuts</h2>
<p dir="auto">Inside Hunter's March, the goal is to keep moving east until the statues on the eastern side come into view. Earlier in the campaign, that area was blocked. Now that Hornet has Silk Soar, she can super jump into the next section and continue exploring Hunter's March from the opposite side.</p>
<p dir="auto">Eventually, Hornet will open a bridge that leads her out of Hunter's March and back into the Far Fields. From that exit, players should continue east until reaching a dead end. The route is not over, however. Hornet must drop down and take a much longer road beneath the obvious path. This lower route winds toward the Heart of the Wild arena, and it is easy to miss if players assume the dead end means the search is over.</p>
<p dir="auto">Step<br />
Route Action</p>
<p dir="auto">1<br />
Start from the Marrow and enter Hunter's March through the only available entrance.</p>
<p dir="auto">2<br />
Head east through Hunter's March, using Silk Soar or a downward-hit crest to bypass tricky spots.</p>
<p dir="auto">3<br />
Reach the eastern statues and super jump into the newly accessible area.</p>
<p dir="auto">4<br />
Open the bridge to exit into Far Fields, then continue east to a dead end.</p>
<p dir="auto">5<br />
Drop down and follow the longer lower path to the Heart of the Wild arena.</p>
<h2>Skarrsinger Karmelita Boss Fight</h2>
<p dir="auto">Once Hornet arrives at the quest location, she can challenge Skarrsinger Karmelita. The fight does not begin quietly. Multiple smaller enemies attack in waves before the boss herself makes an appearance, turning the arena into a loud, chaotic test of positioning.</p>
<p dir="auto">Players should treat the opening waves as a warm-up, but not a free one. The smaller enemies can drain health quickly if Hornet stands still. A good approach is to keep circling the arena, clear the waves with downward strikes or sweeping attacks, and save healing for the gap between waves. When Skarrsinger Karmelita enters, the tempo shifts. Her attacks punish greedy movement, so landing a few hits and retreating is safer than trying to end the fight in one long combo.</p>
<p dir="auto">After the boss falls, Hornet receives the Hunter's Heart and completes the Heart of the Wild quest in Silksong.</p>
<h2>Final Tips for the Heart of the Wild Quest</h2>
<p dir="auto"><img src="https://forum.magpiestuff.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f5fa.png?v=e87f02996ad" class="not-responsive emoji emoji-android emoji--world_map" style="height:23px;width:auto;vertical-align:middle" title="🗺" alt="🗺" />️ <strong>Start from the Marrow:</strong> Shortcuts are blocked, so this is the cleanest route into Hunter's March.</p>
<p dir="auto"><img src="https://forum.magpiestuff.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f98b.png?v=e87f02996ad" class="not-responsive emoji emoji-android emoji--butterfly" style="height:23px;width:auto;vertical-align:middle" title="🦋" alt="🦋" /> <strong>Use Silk Soar aggressively:</strong> It opens the eastern statues and skips older pogo sections.</p>
<p dir="auto"><img src="https://forum.magpiestuff.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2694.png?v=e87f02996ad" class="not-responsive emoji emoji-android emoji--crossed_swords" style="height:23px;width:auto;vertical-align:middle" title="⚔" alt="⚔" />️ <strong>Bring a downward-hit crest:</strong> The plunge attack helps with both traversal and wave clearing.</p>
<p dir="auto">🧭 <strong>Check the dead end carefully:</strong> The real route goes down, not forward.</p>
<p dir="auto"><img src="https://forum.magpiestuff.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f49a.png?v=e87f02996ad" class="not-responsive emoji emoji-android emoji--green_heart" style="height:23px;width:auto;vertical-align:middle" title="💚" alt="💚" /> <strong>Heal between boss waves:</strong> The opening adds can be more dangerous than they look.</p>
<p dir="auto">The Heart of the Wild quest is a compact but memorable piece of Silksong's hidden Act 3. It rewards players who revisit old territory with fresh eyes, and the Hunter's Heart is a worthy trophy for those who survive the detour.</p>
<p dir="auto">Once the Hunter's Heart is secured, the natural next step for many players is to see what else is worth playing—or to finally pick up a title that's been sitting on their wishlist. Steam sales come and go quickly, and keeping track of the best prices can be a chore.</p>
<p dir="auto">That's where DealNest comes in. Its [steam sale tracker]( makes it easy to monitor discounts and historical lows across the store, so you can spend less time refreshing pages and more time playing. Whether you're hunting for a deal on Silksong or something new, it's a handy site to keep in your bookmarks.</p>
]]></description><link>https://forum.magpiestuff.com/topic/139/how-to-reach-heart-of-the-wild-and-claim-the-hunter-s-heart-in-silksong</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 21:55:37 GMT</lastBuildDate><atom:link href="https://forum.magpiestuff.com/topic/139.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 10 Sep 2026 18:54:42 GMT</pubDate><ttl>60</ttl></channel></rss>
