<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to Reach Sinner&#x27;s Road and Get Its Map in Silksong]]></title><description><![CDATA[<p dir="auto">How to Reach Sinner's Road and Get Its Map in Silksong</p>
<p dir="auto">Conquer Hollow Knight: Silksong's roach-infested Sinner’s Road map with exact wall-jump and pogo routes from Halfway Inn to Shakra.</p>
<p dir="auto">From the moment I first poked around above Halfway Inn, I knew Sinner’s Road would be trouble. The narrow platforms, the grab-happy roaches, and the general gloom all scream one thing: turn back. But if you want that map, you have to keep moving. The route is not as confusing as it looks once you break it down. One missed pogo, though, can send you tumbling into a pool of something you do not want to identify. Here is how I finally made it to Shakra and picked up the Sinner’s Road map.</p>
<p dir="auto">Sinner’s Road sits high above Greymoor. It is not the kind of place you stumble into by accident. You need to find a specific lift, complete a platforming gauntlet, and deal with some really annoying enemies. The area feels desolate in the best worst way possible, with roaches skittering around and maggot-infested pools tucked into the corners. Exploring is tense, and finding the map makes the whole thing much more manageable.</p>
<h2>Quick checklist before you leave</h2>
<p dir="auto">Before you start climbing, make sure you are ready.</p>
<p dir="auto">🧗 Wall jump is required. Several sections are nearly impossible without it.</p>
<p dir="auto"><img src="https://forum.magpiestuff.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f98b.png?v=e87f02996ad" class="not-responsive emoji emoji-android emoji--butterfly" style="height:23px;width:auto;vertical-align:middle" title="🦋" alt="🦋" /> Double jump via Faydown Cloak speeds up one specific room, but it is optional.</p>
<p dir="auto"><img src="https://forum.magpiestuff.com/assets/plugins/nodebb-plugin-emoji/emoji/android/2764.png?v=e87f02996ad" class="not-responsive emoji emoji-android emoji--heart" style="height:23px;width:auto;vertical-align:middle" title="❤" alt="❤" />️ Extra masks help. The roaches hit harder than they look.</p>
<p dir="auto"><img src="https://forum.magpiestuff.com/assets/plugins/nodebb-plugin-emoji/emoji/android/23f3.png?v=e87f02996ad" class="not-responsive emoji emoji-android emoji--hourglass_flowing_sand" style="height:23px;width:auto;vertical-align:middle" title="⏳" alt="⏳" /> Patience is non-negotiable. Pogo jumps around cages and saw blades punish panic.</p>
<p dir="auto"><img src="https://forum.magpiestuff.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f5fa.png?v=e87f02996ad" class="not-responsive emoji emoji-android emoji--world_map" style="height:23px;width:auto;vertical-align:middle" title="🗺" alt="🗺" />️ If you have not reached Greymoor yet, work through Far Fields first.</p>
<h2>Step 1: Start at Halfway Inn</h2>
<p dir="auto">Travel to Greymoor and locate Halfway Inn. The lift you need sits just to the left of the inn. It is easy to miss if you are focused on the building itself, so hug the left side. Ride the lift up to the upper platforms.</p>
<p dir="auto">Once the lift stops, head right. You will see several inflated objects floating near the edge. They look playful. They are not. Pogo off them with controlled inputs. Give yourself a second between bounces. I learned the hard way that trying to chain them too quickly sends Hornet flying in the wrong direction.</p>
<p dir="auto">High above, there is a wall on the right side. Use wall jump to scale it. At the top, look for a cave opening on the right. This cave is your entrance into Sinner’s Road. Once you slip inside, the atmosphere shifts instantly.</p>
<h2>Surviving the entry stretch</h2>
<p dir="auto">Inside Sinner’s Road, keep moving right. The ground is absolutely crawling with roaches. They do not wait for you to get close; they pounce. Hornet can get caught mid-move if you are not careful, and the grab attack eats health fast. My advice is simple. Stay off the floor whenever possible. Climb onto the hanging cages and hop from one to the next. The spacing feels awkward at first, but the rhythm becomes familiar. Trust the cages over the ground.</p>
<p dir="auto">Continue right until you spot a sign marked with the bench symbol. That sign is your cue to climb higher. Use wall climb and enter the next pathway on the right. This leads into a larger room with a vertical challenge.</p>
<h2>Two ways up in the cage room</h2>
<p dir="auto">This room can slow you down if you are not prepared. There are two ways to reach the upper platforms. One is a shortcut, and one is the longer route.</p>
<p dir="auto">Method<br />
Requirement<br />
Difficulty</p>
<p dir="auto">Wall and double-jump shortcut<br />
Faydown Cloak ability<br />
Easy</p>
<p dir="auto">Saw-blade pogo route<br />
No special ability required<br />
Moderate</p>
<p dir="auto">If you have double jump, life is good. Right above the entrance, grab the wall and climb to the hanging cage. From the cage, jump left to gain a little height, then double jump right onto the platform. It sounds precise, but the window is generous. Once you land, breathe.</p>
<p dir="auto">If you do not have double jump, do not worry. Head to the rightmost part of the room. You will see hanging saw blades. These are your pogo points. Bounce from blade to blade until you reach the top. Treat each bounce as its own tiny decision. The moment I started thinking two bounces ahead, I fell. Focus on the current bounce only.</p>
<p dir="auto">Whichever method you choose, drop to the left side once you are high enough. Hit the switch to unlock the gate. If you hear the gate open, you are on the right track.</p>
<h2>Reaching Shakra and the map</h2>
<p dir="auto">Go through the unlocked gate. Beyond it, jump over two hanging cages. Watch your spacing here, because a miss means falling back into roach territory. You will see a doorway marked with the bench symbol. Enter that doorway.</p>
<p dir="auto">After a short platforming section, you will meet Shakra. This merchant sells the Sinner’s Road map. Buy it immediately. Having the map changes everything because the area stops feeling like a maze. You can finally see where the pathways connect and where the dangerous rooms sit.</p>
<p dir="auto">There is also a bench near Shakra. If it is inactive or damaged, you may need to fix it before resting. Either way, this is a major checkpoint. Rest if you can, then plan your next route through Sinner’s Road with the map open instead of guessing.</p>
<h2>Final tips before you go</h2>
<p dir="auto">Roaches are the biggest early threat. Stay high and keep moving. Do not fight fair on the ground. The saw-blade route is entirely doable without double jump, but it wants patience more than skill. If you fall, do not tilt. The route is shorter than it feels. Buying the map first makes every return trip far less stressful. Honestly, reaching Shakra felt like a small festival of relief. And in a place as hostile as Sinner’s Road, any relief is worth chasing.</p>
<p dir="auto">That covers the path to Sinner’s Road and its map. Get the lift, climb the walls, choose your route carefully, and let Shakra sell you the one thing that makes the fog lift. Good luck up there.</p>
<p dir="auto">Getting through a place like Sinner’s Road is a small victory, but it is also a reminder of how much planning can smooth out an otherwise punishing experience. The same logic applies outside the game itself. Before you commit to your next sprawling adventure, it is worth putting a little of that careful strategy into where you buy your titles. A quick [game price comparison]( can save you enough to justify adding that extra DLC you have been eyeing, or to pick up another indie hidden gem on the side. Smart explorers check their route ahead of time; smart players check their storefronts too.</p>
<p dir="auto">So after you finally rest at that bench and let the name of Sinner’s Road fade into just another mark on your map, take a moment to enjoy the win. Then, when the next journey calls, let DealNest help you decide which world is worth entering next. Fewer coins spent getting in means more time spent mastering what waits inside — and that is the kind of advantage every player can appreciate.</p>
]]></description><link>https://forum.magpiestuff.com/topic/114/how-to-reach-sinner-s-road-and-get-its-map-in-silksong</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 22:39:58 GMT</lastBuildDate><atom:link href="https://forum.magpiestuff.com/topic/114.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 05 Sep 2026 05:14:53 GMT</pubDate><ttl>60</ttl></channel></rss>
