<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[I Stumbled Into Silksong&#x27;s Secret Plasmium Phial Trick That Makes Hornet Nearly Unkillable]]></title><description><![CDATA[<p dir="auto">I Stumbled Into Silksong's Secret Plasmium Phial Trick That Makes Hornet Nearly Unkillable</p>
<p dir="auto">Hollow Knight: Silksong and Plasmium Phial offer a brutal challenge; mastering Lifeblood Hearts transforms survival in Pharloom.</p>
<p dir="auto">Let me set the record straight: I did not discover this. I am just the traveller who spent a dozen hours in Pharloom getting carved into ribbons by common mobs because Hornet's health bar refuses to cooperate. In 2026, Hollow Knight: Silksong has already earned a reputation as a brutal sequel, much harder than anyone expected. Diagonal-bounce platforming feels like trying to fold a fitted sheet while juggling, and the bosses make the Lost Kin look like a friendly tutorial. Then I saw WikiWitIT's video about the Plasmium Phial, and my entire approach changed.</p>
<h3>The Phial That Looked Like a Novelty</h3>
<p dir="auto">The Plasmium Phial is rewarded after you finish a side quest called Alchemist's Assistant for Alchemist Zylotol in Wormways. You collect three pieces of Plasmium and receive the tool. On the surface, it lets Hornet stack Lifeblood Hearts, which are bonus health slots that last until you rest at a Bench or lose them by getting hit. My first impression was not generous. Compared to tools that deal damage or open paths, a health-stacking phial felt about as exciting as a sundial in a lightless cave. But Silksong punishes health management far more than Hollow Knight ever did. Regular enemies frequently deal double damage, so every extra Lifeblood Heart feels like a small miracle.</p>
<h3>The Bench Trap and the Architect's Crest</h3>
<p dir="auto">The catch is that resting at a Bench refills your tools, but it also strips away the Lifeblood Hearts you stacked. At first, the phial seems capped by the bench cycle. You stack a few hearts, use the phial's charges, sit down, lose them all. It felt like trying to carry moonlight in a basket. Then WikiWitIT showed the workaround. Find and equip the Architect's Crest, a trinket that lets you replenish tools without using a Bench. From there, keep stacking Lifeblood Hearts. Do it enough, and you trigger a hidden state that nobody had documented until now.</p>
<h3>What the Hidden Overdose State Feels Like</h3>
<p dir="auto">Once the secret effect kicks in, Hornet's ordinary health is effectively replaced by Lifeblood Hearts. The bar no longer behaves like a finite resource. Instead, it trickles back over time, as if the hearts are refilling themselves from some unseen reservoir. In combat, this feels less like standard Silksong survival and more like fighting with a suit of armor that quietly sews its own wounds. I took a triple-damage swipe from a heavily armored sentinel, waited a few seconds, and watched the red edge creep back. That was the moment I understood the hype.</p>
<p dir="auto">Here is the short version for anyone who wants to replicate it:</p>
<p dir="auto">Complete the side quest Alchemist's Assistant for Alchemist Zylotol in Wormways.</p>
<p dir="auto">Collect three Plasmium to earn the Plasmium Phial.</p>
<p dir="auto">Find and equip the Architect's Crest so you can refill tools without resting at a Bench.</p>
<p dir="auto">Keep stacking Lifeblood Hearts past the normal limit.</p>
<p dir="auto">Trigger the hidden effect and enjoy passive health regeneration.</p>
<p dir="auto">Situation<br />
Normal Plasmium Phial<br />
Overdosed with Architect's Crest</p>
<p dir="auto">Health type<br />
Temporary Lifeblood Hearts<br />
Lifeblood Hearts replace main health</p>
<p dir="auto">Regeneration<br />
None, only refill at Bench<br />
Passive regeneration over time</p>
<p dir="auto">Survivability<br />
Helps, but fragile<br />
Dramatically harder to kill</p>
<p dir="auto">Known duration<br />
Until rest or hit<br />
Unconfirmed, possibly story-gated</p>
<p dir="auto">Right now, no one has pinned down exactly how long the passive regeneration lasts, or whether there is a hidden cost. Some players suspect the effect may fade when you reach certain story thresholds or after a fixed number of hits, but nothing is confirmed. Abusing the Plasmium Phial like this does not seem to disable achievements or soft-lock a save, but treat it as an exploit-adjacent trick until Team Cherry decides whether to patch it.</p>
<p dir="auto">For anyone still getting shredded by double-damage mobs, the sequence is simple: finish Alchemist's Assistant, grab the Plasmium Phial, find the Architect's Crest, and stack Lifeblood Hearts until the game stops counting. It changes Hornet from a fragile needle-dancer into something much closer to unkillable. Just be ready for the conversation to shift again when the inevitable balance patch arrives.</p>
<p dir="auto">If you are planning to test this hidden Lifeblood state before Team Cherry rolls out a fix, it is worth keeping tabs on the broader Silksong conversation. Patch notes and community discoveries land fast, and a trick like this one can vanish overnight. Between hunting for secrets like these, many players are also using the downtime to stock up on other metroidvania titles that scratch the same itch, and keeping an eye on [DealNest game deals]( is a reliable way to catch discounts on similar action-adventure games without missing a beat.</p>
<p dir="auto">Whether you are chasing undocumented exploits or simply want a fuller library for your next playthrough, a little preparation goes a long way. Bookmark the page and check back whenever you need a break from grinding Lifeblood Hearts, so you are always first in line when the next hidden mechanic surfaces.</p>
]]></description><link>https://forum.magpiestuff.com/topic/105/i-stumbled-into-silksong-s-secret-plasmium-phial-trick-that-makes-hornet-nearly-unkillable</link><generator>RSS for Node</generator><lastBuildDate>Fri, 11 Sep 2026 23:21:21 GMT</lastBuildDate><atom:link href="https://forum.magpiestuff.com/topic/105.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Sep 2026 02:45:50 GMT</pubDate><ttl>60</ttl></channel></rss>
